wiring 2ohms and 4ohms sub together
ikoolguy
the title pretty much sums it up
i have jl 500/1 amp and 2 subs one sub is 2ohms and the other is 4ohms. a friend told me i can wire it into 3ohms.
well i did a little research online and said it will do some damage
should i be worry about my amp and my car?
or will it be okay to run the subs at 3ohms?
Why not? I mean...if the end load is 3 ohms, each sub would be getting the power.
Wire the DVD 4 ohm to 2 ohms, then wire the DVC 2 ohm into 4 ohms. Then parallel the subs together to get 3 ohms. Is this possible?
are you the said 'friend'?
one d3 is 2ohms and the other d3 is 4ohmsi got it wired to 3ohms
is it safe?
so the dvc 4 is parallel for 2, the dvc 2 is parallel for 1, subs are in series for 3??
That should work fine. One sub moving less than the other isn't going to have any real effect on sq.
ikoolguy
ikoolguy
waveland, ms
n2audio
