wiring 2 subs w/ 2 ch. amp
  • 2
Jake
5
Iowa
ok i got 2 punch 15s and a dual box wher e both subs will have seperate chambers. ( there no hole in the middle.) so i cant wire them 2gether, so i just run + to + and - to - from the sub to the outlet, and do the same on the other side, right? and my amp is a 150Wx2 at a 4 ohm load, and the subs are 150 Rms. i think that would be perfect b/c i think i would have 4 ohm load for both channels. is that right? also wut size wire should i use? i mean just inside the box for wireing the subs to the outlet or wutever that thng is called. i have 16 ga. rite now but does it need to be biggfer than that? thanx
Sounds right.
16 gauge wire will work fine. 12 -10 is better. Anything between the amp and the speaker will reduce the damping factor. So to maintain a high damping factor use thick wire. And keep the amp close to the speakers.
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
Wire to the 2ohm diagram as shown for the MTX subs on the one amplifier you have. That amp should do very well on those two subs. alpine make some...
Sure, 600 volts, yep. If you’re trying to launch the subwoofer cones to the moon! And, that’s if they don’t just vaporize first!
34
4K
Sell the dual 2 and get another dual 4.
Jake
Jake
Iowa
indosia
vlusardi
    Apr 27, 2024
winkychevelle
    Apr 27, 2024
Latest topics
