wiring 2 dvc 6 ohm subs to mono amp
achallie
bmt
So let me throw this out there. What if I wire 1 dvc sub in series to get 12 ohms and 1 dvc sub in parallel to get 3 ohms and then connect those in parallel to end up with a 2.X ohm load at the mono amp?
dvc sub 1 in series: 6+6=12 ohms
dvc sub 2 in parallel: 6*6/6+6=36/12=3 ohms
(2) dvc subs in series to amp: 12*3/12+3=36/15=2.4 ohm load at amp
Amp: Infinity mono 611a
subs: Audiobahn Alum8p
u cant wire to a 2 ohm, u can wire to a 1.5 ohm which is wut i just got done wiring my friends alum12's to. U might want a little bigger wire though if ur amp is only 2 ohm stable cuz his gets hot after a bit. Wire all of your negatvies together and lead them to the negative on the amp, and all of ur postives together to the postivive amp channel.
If you look at the math it is possible I think. 1 sub would be wired to 12 ohms (in series). The second sub would be wired to 3 ohms (parallel). Then, both subs would be wired in parallel to the amp to develop a final load of 2.4 ohms.
I think it would physically work but I'm not sure what power each voice coil will actually receive. I'm thinking it will result in one sub being underpowered and one being nominally powered, but the ohm load would be within spec of the amp.
Actually MIN impedance would be right around 6 ohms but that could vary greatly with enclosure. You really should be ok with a decent amp running it at a nominal 1.5 ohms (everything parallel) because it will probably not ever see that actual load.
As far as wiring one in series and one in parallel, the one in parallel will get 4x as much power as the one in series.
achallie
achallie
bmt
helotaxi
Old_risk
    Jun 23, 2026
Old_risk
    Jun 23, 2026
