Wire gauge help
Nugg32
I have two Sa-12 D4s with a saz 1500d v.3
1. im not really sure the best way to hook my subs up with my stock alt and battery
2. im going to guess 4 guage for power wire but im not really sure what else i should be using
You want 0ga with an amp like that, especially if you intend on adding a separate amp for you cabin speakers. For the subs, you can wire them to either 1ohm or 4ohm. 1ohm is going to max out the power of that amp, but at the expense of more work on your electrical.
ill probably go with the 4 ohm till i get a better alt and battery. Thanks
Nugg32
Nugg32
Ohio
Nugg32
