WinISD 6th order graph, good, bad?
jj53913
Ok I'm tring to educate myself with this program and 4th and 6th order boxes. One day I would like to build one. I don't know exactly what the graph should look like, this one has a narrow but flat response, it rises above zero at 28.25hz and rises to 3db and drops back to zero at 74 Hz.
Wondering if that's any good thanks for any input
I'de use bassbox over winISD, personally.
With a box as sensitive as a 6th order, i had much better luck my first go-around by using bassbox pro and taking in characteristics of my vehicle responses from prior setups. I'm not sure if you can do that in winisd.
while you're learning, might as well learn to use both.
Your all good I don't get affended on here. I was using this program because its free wasn't really wanting to buy a program, might end up doing that one day I guess, usally free programs aren't quite as good as ones u have to pay for
jj53913
jj53913
Ontario, Oregon
cj407
