Will this Terminal Cup fit 8 gauge wire??
dude, if you have 8 ga. SPEAKER WIRE, you are past t-cups.
this is what I use:
can be found in electrical at your hd or lowes.
... well crap. I just bought a reallly nice terminal cup that fits 8 gauge wire. I might send it back when I get it or something, we will see. What you are using looks pretty simple and really cheap. Does it work well?
yep. I drill a hole just big enough for the bolt. use washers on both sides. you COULD use ring terminals, but I like these square things better.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif they are grounding blocks for breaker boxes i believe.
did you make sure to seal up the inside of the hole?
You can buy 8AWG binding posts and the plate to mount them online at parts express. That is what I do. You can get the plates in blue or black or red and they are annodized, look really nice. I like yours too DJMAN37!
TacoSauce
TacoSauce
Orlando
spin dB
michigan born
    May 14, 2026
michigan born
    May 14, 2026
