Will this sub work with this amp...
400 watts is a suitable ammount of power in either scenario.
The only place you may be concerned with is the ohm load presented by each sub at the amp. Most standard subwoofers are the single 4 ohm type, which when ran in pairs would equal either a 4 ohm stereo, 8 ohm mono, or 2 ohm mono load at the amp; when wired in stereo, series, paralel, respectively.
take it easy,
-zane
400 watts? 300RMS? Are you shure? If the amp says 400 watts peak it wont be 300 watts RMS. it will be only 141.1 watts RMS peak power is what manufacturers put there to impress people RMS means. (Root Mid Scuare) the part the Amp. will really use without distortion. this is my tip of the day for free. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
the amp is a profile....let the slamming begin. lol..it's not my main amp though. i'm just working on puting a cheaper system in my old car, cuz i'm selling it, and my friend agreed to buy it if it has a mediocre system...so i'm just using one of my old amps
Again, you should be allright.
Profile makes some incredibly good "Bang for the Buck" amps. I am in fact using a Baja 600 powering a Rockford Punch HE2 15 in my sisters car. No complaints or problems for the last year and a half it has been installed.
Just keep the amp above 2 ohms and it will work fine.
take it easy,
-zane
So the 400w amp will power either 2 lower grade 10's or a single 12" fine? Ok, well in this case, which will be more suitable...meaning, more suitable for my music and my friend's musical preferance (remember, i'm not keeping this system..just putting it in for a friend in my old car). I, as well as he, listen to mostly rock, hard rock, alt, and some rap. mostly rock-type music though. So, would two 10's or a single twelve sound better? I still like a deep, full bass that fills the car, but still gives good sound quality and compliments the music. any help would be great
627
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
740
Hahaha his brother got some from a friend. American bass amp and some alpine s 12in subs. From a buddy of his now Eastons chomping at the bit...
740
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
bumpinthanite
i like cars. a lot.
bumpinthanite
the hills of Michigan
Wonderbread
    May 24, 2024
