will this sub work with my amp?
That set up would be fine if you do not abuse it. As with anything, you cannot just throw the stuff in your car and crank it into clipped oblivion for hours on end..it won't work that way. If you keep the signal clean and have enough common sense to know when you are pushing too hard, you will be fine.
Yes the Ab sub would be better and will take the power of the amp better too The amp is twice the power rating of the rf sub it will work you'll need to set the gains right. And be easy of the sub which most of us don't
These would be my personal choices for one 12 sealed in order on the P1000bd...no data on the actual power handling of the Nak, but they are reported to be top notch for SQL and made in Japan instead of China. I would not be afraid to run it daily. Since you are going sealed, then being loud is not your priority, with a good system tune and a concern for the life of your equipment and desire for SQ, it would be fine.
Overall, the GCON would be the best choice, IMO.
GCON-12 Sound Solutions Audio 12" 750W GCON Series Subwoofer - SSA STORE
WoofersEtc.com - SPW-1210 - Nakamichi 12" 1200 Watt Sound Quality Competition Subwoofer
Obsidian Car Audio
Sundown Audio SA-12 600 watt sub woofer
emd023
emd023
morgantown
mclerico83
