sealed box has no port.....those dimensions you gave with 3/4" wood , will leave you around 2.75 cubic feet after sub displacementwhat would my dimensions look like for a 3 cube sealed box then? would i just be taking away port area?
^^ This.sealed box has no port.....those dimensions you gave with 3/4" wood , will leave you around 2.75 cubic feet after sub displacement
i no sealed box has no port but you said a 4 cuft box ported or 3 sealed.. do i get down from 4 ported to 3 sealed by just subtracting the port area?... so one of my dimensions would be cut down a few inches from ported to sealed right?sealed box has no port.....those dimensions you gave with 3/4" wood , will leave you around 2.75 cubic feet after sub displacement
would u suggest i just get a single nice 12" then?^^ This.
You have no room to go ported... barely have enough for sealed. Even still, it'll be lacking in output due to lack of space. (Won't lack too much, though.)
no......and noi no sealed box has no port but you said a 4 cuft box ported or 3 sealed.. do i get down from 4 ported to 3 sealed by just subtracting the port area?... so one of my dimensions would be cut down a few inches from ported to sealed right?
its not as simple as designing a sealed then throwing a port on it, or taking a port away from ported and making it sealed. I wish it were that easy, but its notwhat makes a sealed box less CUFT then?
and what would u recommend as a sub in the $150 range.. i was thinkin a 12" type r?
wat?IF your box is sealed than it is slightly too small if you have tons of power it wont matter much. Building a ported box at 4 cubic feet would yield more output with any wattage however.
x2IF your box is sealed than it is slightly too small if you have tons of power it wont matter much. Building a ported box at 4 cubic feet would yield more output with any wattage however.
