Will This Setup Work?
roly
Hey, i'm new to this type of stuff and just wanted to see if someone could tell me if this setup will work and what would be the best way to hook it up...I already have these subs and the amp they were given to me so im not going to buy any other ones.
Subwoofers x2: JL Audio 10W0v2
Amplifier: JL Audio XD 600/1
10W0v2 DRIVER SPECIFICATIONS
10W0v2-4
Free Air Resonance (Fs): 32.09 Hz
Electrical “Q” (Qes): 0.640
Mechanical “Q” (Qms): 10.752
Total Speaker “Q” (Qts): 0.604
Equivalent Compliance (Vas): 1.095 cu. ft. / 31.01 liters
One-Way, Linear Excursion (Xmax)*: 0.45 in. / 11.4 mm
Reference Efficiency (no): 0.154%
Efficiency (1W/1m)**: 84.07 dB SPL
Effective Piston Area (Sd): 48.909 sq. in. / 0.0316 sq. m.
DC Resistance (Re): 4.280 ohm
Nominal Impedance (Znom): 4 ohm
Thermal Power Handling (Pt): 300W
Driver Displacement: 0.034 cu. ft. / 0.96 liters
Net Weight: 7.50 lbs. / 3.40 kg
* Xmax specifications are derived via one-way voice coil overhang method with no correction factors applied.
** Efficiency (1W/1m) is not an accurate indicator of a subwoofer's output capability and should not be used as a comparison to other subwoofers to determine which one is "louder".
Your subs are SVC4 and each want 300 watts. Your amp does 600 watts at 2 ohms. Wire your subs like this:
Then just make sure you read up on how to properly set up the gain and other settings on the amp. No reason to buy any new equipment, thus will work nicely.
roly
roly
gulfport, ms
daboyfrumdabx
