Will this amp and subwoofers work correctly?
cory551
Okay, so I have...
2 pioneer premier dvc 2ohm subs.
and I was running a mono amp on it before, and it would run the amp back to .5 ohms or 1ohm no matter how it was wired, so i went and got a 2 channel amp.
I got a power acoustik 2600 lfa series amp. running at 2ohms, i believe it will put out like 600watts to each sub, and the rms is 800, so should be okay.
anyway, I looked at the wiring diagrams on crutchfeild, and i'm starting to worry.
it shows:
http://akamaipix.crutchfield.com/ca/learningcenter/car/subwoofer_wiring/2DVC_2-ohm_2ch.jpg
since it's a 2ohm sub, does that mean that the amp has to run at a 4ohm load?
If this thing puts out what it's rated for (which I doubt it does), then:
# RMS Power Output @ 4 Ohms : 450 Watts x 2-Channel
# RMS Power Output @ 2 Ohms : 540 Watts x 2-Channel
# Bridged Power : 1080 Watts x 1-Channel
If you wire each sub to 4 ohms, you could give them 450W each.
cory551
cory551
Boston, MA
tEh ShOcKeR
Mike Mccabe
