will these subs and amp work together
Your amp is actually a 500 watt amp... I would look for a sub that has a rms of around 200-250. You'll probably want to get DVC 4 ohm woofers so you can wire to 2 ohms and use each channel, or wire them both to 4 and bridge the amp. I would look into maybe Resonant Engineering RE... http://www.reaudio.com
1200W peak power
500W RMS (continuous) x 1 @ 4 ohms, bridged
250W RMS (continuous) x 2 @ 2 ohms
200W RMS (continuous) x 2 @ 4 ohms
The specs on your amp. So eiher get one of the kickers you are wanting make sure it is single VC 4ohm or dual VC 2ohm. That will get you the most power from your amp. x2 on the http://www.reaudio.com and the RE series love there subs.
Marketing rockinguitar. Most cheap equipment does that, makes exorbitant max power claims but fails miserably in actual output for people who don't know better. I can't tell you how many people I've told to not tell me the max power and completely ignore it and look at RMS. Most people don't know what RMS power is and only look at max power, so cheap companies take advantage of that.
honestly not sure if the box is single or dual chamber, its being shipped to me now. i believe it has two separate chambers though
jeff45
jeff45
mass
jeff45
