AUDIOBAHN AW1251T 12" SUBWOOFERS 800 watt peak 400 watt on ebay with mirrored glass bandpass box $160 plus 60 for shipping
is this a good deal? will it compliment my audiofonics amp? specs below.....also how would i wire it to my amp (diagram) since the ad says "subs are prewired to 2 ohm". i mostly play rap......i want deep thundering bass
amp specs
1500w MAX
POWER OUTPUT:
2 CHANNEL [2 OHM] 300W x 4
2 CHANNEL [4 OHM] 200W x 4
1 CHANNEL MONO [4 OHM] 600W x 1
2 OHM LOAD CAPACITY
VARIABLE LOW [30-500Hz] PASS FILTER
VARIABLE HIGH [50-1KHz] PASS FILTER
SUBSONIC FILTER 10Hz-100Hz
BASS BOOST
W x L x H: 270 x 358 x 32mm [10 5/8†x 14 1/16†x 11/4â€]
they will have no sound quality whatsoever. you still want fq range if you listen to rap. i do and there is quite a bit. but if you listen to lil john it will be very loud but very crappy.
btw: those are the lowest end of bahn's.(not a hater). rms is usually 1/2 the peak. the amps rms should be > the subs. fq= frequency. those subs are not the absolute best. it will depend on your budget
based on my amps specs please tell me what speakers I should look into. I want the absolute best. can my amp dish out enough watts? the amp i own is the adf-243. I am willing to invest around 200-300 for 2 subs but i want the best
