squeak9798
Banned
And in your scenario our feet,the things in contact with the conveyor belt, provide the force for our movement. THIS IS NOT THE SAME CASE AS WITH AN AIRPLANE. The airplane's force is provided by it's engine, NOT it's wheels.that is assuming both the treadmill and the plane are traveling in the same direction. think of the moving sidewalks in the airport. they move you at about 3mph, give or take. if you get on the sidewalk and stand still you are moving forward at 3mph. if you walk in the same direction of travel as the sidewalk at 3mph, you effectively double your speed and move 6mph. But if you walk in the opposite direction of travel from the sidewalk at 3mph, your forward movement and the sidewalk's backward movement negate each other and you have a net velocity of 0mph.
To correlate this to your example, let's pretend we are facing backwards on the airport conveyor......so it is traveling at 3mph in the opposite direction we are heading. However, instead of walking on the conveyor belt, we are wearing roller skates, and our "force" or "thrust" is provided by our friend (standing on solid ground) pulling us with a rope. If he pulls us at 3mph in the opposite direction of the conveyor belt, will we move ?? The answer is YES, WE WILL, at approximately 3mph.
This case I present is equivalent to an airplane on a conveyor belt. Your example of us just "walking backwards" is NOT, because an airplane's thrust is NOT provided by it's wheels.
Wrong.the plane would be traveling opposite the direction of the treadmill, so the velocities would negate each other and the plane would have an effective velocity of 0mph (in relation to the surroundings)
