Will my system hit?
People don't have underglows because they are gay. You like them because you are gay... yet you are calling me gay. You wish I took it in the *** so you could hit on me... but I don't and you can't. You didn't know anything before and you still don't. I didn't flame you until you kept asking the same things over and over and never could comprehend anything. You started a million threads rather than simply reading to find out because you're stupid. It's obvious that you're stupid. Also, mixing batteries is not recommended because batteries usually float at different charges. This will be caused by different make up (meaning SLA and AGM, etc) and different age. You're supposed to use the exact same battery and the exact same age of battery so that the float charge will be as close as possible. If they are not very close, they will continually discharge to each other trying to reach the same level of charge. Depending on the difference, the amount of life will either be reduced by a lot or very little. Consider yourself informed.
LOL okay..so I called you a **** and now your trying to say im gay because I have underglow..this is a waste of time..at first it was just your opinion that underglow was gay to your own discretion but now its gay because im gay..your changing the story around...
You lied. In the post of mine that you quoted I never said underglows were gay because you like them. I said you like them because they are gay. It's right there in black and white. You're either too stupid to understand or you're a liar. Either way... epic fail.
you calling me gay is just a cover up of your sexuality secrets..At first you said underglows were gay and then you said im gay and now your saying I like them because im gay...wow..which one is it?
and you coming into peoples threads flaming them because they are new and dont know what they are talking about is gay..
read my posts man..this argument is just going in circles.
I'm sorry, but you aren't being very intelligent over this. You need to read over basic electric principles.
Attempting to pull 150+ amps (2000 watts off of 12-13 volts) through 5 gauge wire is going to fry the wire. It will blow the fuses (if you have any), melt the wires, and possibly cause a fire in the car.
Trust me when I say take the **** time.
Also, Eclipse subs are fairly nice, I'd much rather have one of them than yours. Kicker subs do not sound good. The prefab kicker ported box is NOT custom. It's a pos that needs to be burned. I don't care that your in high school, while I was in high school, two jobs, a girlfriend, and more AP classes than I could count, family troubles, I managed time to put together an IB setup involving cutting up the rear of my trunk. I know how it is, you have time, you're just lazy and spend the time on a forum instead of doing it when you can. Then you get busy and use it as an excuse.
u is mad
You're grasping at straws. You're lying right now. Since you made the claim and since we are posting on forums there is a record of what was said. I have called you a liar. Now prove that what you said is true or stfu. You're the one that started with the gay putdowns... finish it by proving what you say or OBVIOUSLY proving that you're a liar.
Skits89
Skits89
NY
fyerbyrd22
