Will I regret getting my system installed at Best Buy?
The issue with my speaker is basically what we had with our home cinema setup with one of the rear speakers; it turned out we just need to strip about an inch of wire back and re-do the connections. You guys reckon it's the same with my car speakers? I can't be ****ed if they have to re-do the whole thing...
if thats what it takes make them do it. you paid for a working install, you did not pay for that problem.
oh so negative and postive are the same current? thanks bill nye!!
Was that a joke? It is the same current. Ha?
However, I do not necessarily buy into the idea that running the RCA's through your chassis is the same as running it beside your power cable. The power cable will be handling the entire current directly, while the ground path through the chassis means the current will be spread out over a much larger area, thus creating a much less significant magnetic field in an one localized spot like your RCA's.
amen.. you had no part of the problem.. you go to a restaurant and they mess up your order you don't pay for it and the replacement.. they fix it and bite the cost of the mess up.. alot of times depending on error size they give you a discount or free aswell because they want repeat customers..
I was thanking him for being captain obvious and a science teacher..
So you agree with him that it doesn't matter even if you zip tie your RCA's and power wires together, since you are already sitting the wires on the ground path conductor anyway?
no.. like you said above.. you have shit tons more direct path going through that cable then spread out through the entire frame although most will head through one spot as it will find the easiest method of traveling.. now then good shielded rcas and you won't have a problem.. but cheaper rcas you might..
im a bay manager at best buy and i will say this....your problems with your install are your own fault for not checking to see who was doing your install first and checking to see if they know anything and asking to see if they have any documentation of their work....I can say about bb install bays that they are very hit or miss in some cases you will find phenomenal installers such as the couple nominated for installer of the year in others you will find complete idiots but determining which will be working on your car is on you. Unlike the rest of these idiots on this forum i would not write bb off completely...i would likely avoid that one from now on and make sure i check next time....now that being said the EXACT same thing can be said from custom shops anywhere...some cases phenomenal other cases idiots. So to all those that say bb and cc are the worst the same should be being said for all custom shops out there. SO in the future before going to a custom shop or bb or cc ask if the installer has some documentation of their work hell i have a titled a notebook of my installs that sits on the counter here have it is custom work and not shit i do here but it gives the customer an idea of the work they are going to get and any other installer that takes any pride is his/her work will likely do the same.
Just as was said above, don't write BB off yet. I have worked in the bay before. Were you contacted about the extra 200 bucks, if not they have to mark on the invoice you were contacted and approve the extra cost. Secondly, it may **** to be "that guy" but you may have to yell and scream until you get your point across. Bring up the fact he was hanging out with his friends instead of working on your truck. Bring up the lame excuse. Bring it up over and over, his manager will not know what the problem is, they don't know anything about installing. Also, were you told about the "modifications" to the doors for the tweeters, if not have them buy you new door panels. You must have full disclosure before they do any work. Sounds like this kid was just wanting to be called an installer and you unfortunately got stuck with him on your truck.
Worlddre sounds like he would have taken care of your truck, just as I would have. Hopefully the will cover everything and it will not be that big of a deal. Good deal.
which BB you work at in Bowie?
Limey turncoat
Limey turncoat
Naples, FL
Plutoman
BP1Fanatic
    Jun 2, 2026
BP1Fanatic
    Jun 2, 2026
