Will a bad desing on the box damage a sub?
Max dimensions?
I guess that'd be an infinite baffle alignment, anything over 4 times the speaker's Vas...
Some drivers do well in that environment, others don't...
Tuning higher than you think is another problem, you'd be unloading the driver below tuning and running into possible mechanical problems.
Try to stick near the recommended...going over will reduce power handling and make it easier to reach the mechanical limits.
You're welcome.
well I actually want to go under not over this spec ........ I need to take out 1'' or 2" on all the general dimension what do you think?
Octavio
Octavio
Nic
Octavio
