Will A 4 channel amp bridged give me stereo sound?
I have a jl audio 4 channel amp producing 4 x 75 rms. If i bridge the the channels i will get 2 x 150 rms, but will the sound be stereo or mono?
Depends on how you run the interconnects to the inputs. You will need to put two lefts on the front channels and two rights on the back channels, or vice-versa, but you get the idea.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
As long as you run only the left signal to channels 1&2, and only the right signal to channels 3&4, yes you'll have stereo sound.
You can run a bridged 4 channel in stereo by connecting the left output from the head unit to one set of bridged channels and the right output to the other set of bridged channels.
Uh, stereo, since it's not a mono amp. Mono just refers to the whole one channel application.
Mono can also refer to the type of sound being produced.
If I only input the left signal to every input on a 4-channel amplifier, the resulting sound would be mono even though I have "four channels"
282
10
675
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
802
Okay, I'll bite. If you're going to get rear speakers, get the same ones (model type, doesn't have to be the same size) that you have up front...
I would keep the amp you have and keep the components. Place the components in some universal door pods, and look at getting a powered SAS 8"...
13
aaftab
aaftab
uk ;ondon
squeak9798
    May 24, 2024
    May 23, 2024
