wierdest problem with pioneer cd player
check the fuse box, amp and deck for a blown fuse... mine did the same thing and i freaked out and it was my fuse box.. if it is your fuse box you might want to bump it up about 5 more amps cause you have a large amp
Agreed. Check the fuse box under the dash, secondary fuse box under the hood, but more than likely, the fuse on the power or ACC wire on the HU, or the HU itself.
If you own Perfects you blew them because, essentially, that's what they do best. Brittle, poorly designed woofers with many flaws. If not, your gain was too high, your box was too big, played below tuning or whatever else. I can't specify if I don't know the minutae of the system.
missionpilot
missionpilot
Gulfport, MS
Mark_ab
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
