wich is better?
MS-62C sounds very good, but it's also discontinued. JBL does not have replacement parts, and the woofers have a known issue of failing under normal use. It would be a risky purchase, in my opinion.
The metal tweeter on the ms line is prolly the best metal dome for the price. Only other metal domes I like is the Jl zr, and the Memphis m class
which is the difference in a tweter are cloth and metal?
Why did jbl discontinue the ms line they where some of the best sounding of the common man shelf you could buy.
failure rate of the tinsel leads is pretty common. They should have sown on the leads instead of leaving it to flop around when the driver can put out lots of excursion. Sounds great when it works, real smooth, warm and midbassy, However, not loud enough to keep up with anymore then 2 12s on 1200 watts.
corobore
corobore
vv
SIQUISIQUE
vegang
vegang
