Why the 5th Wire on a LOC?
  • 5
Well here is my problem, Just hooked up LOC sub and amp, and the AMp comes on and DOES NOT go into protect, but the sub does not...I know the sub works, Tested it alrready. How can I double check the Amp without Un hooking it?
use either a tone generator through the rcas.....the end of the rcas and touch them to grund real qucik while the amp is on....either way if all is well with the amp the sub will make noise
I think it is Blowdid up, Well good thing I bought it from someone's at THERE house...they will be giving me my money back after I make sure it isnt anything stupid...
This is what I ordered from Amazon. https://www.amazon.com/gp/product/B07MXMPHKS/?tag=caraudiocom-20...
352
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
844
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
984
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
978
DeViOuSoNe
What's a Subwoofer?
DeViOuSoNe
MD
Qbenjamin
