why that was nice
Should i start using crystal meth?
  • Sure...its not that bad...
    Votes: 93 62.0%
  • Just say no!
    Votes: 57 38.0%
  • Total voters
    150
zomg dood get it
I did. It should be here on wednesday.
Doesn't it do the same thing as a $20 remote from walmart? Turn the TV on and off, adjust the volume, and change the channel
I havent found a $20 remote at walmart that will control my HT, DVD, DVR/SAT, TV, and CD. My current remote (without Pc programming) wont control everything out of the box and has a limited amount of memory for learned commands. I cant fit all the commands for all my equipment in its memory.
I just want one remote that will have every function for all equipment.
only remote i need,
Harmony remotes are nice. I use to work at Best Buy and they always had one in our demostration area. Its nice being able to press one button and it will turn on your reciever, tv, and whatever else on all at once and turn anything else thats not necessary off.
I have a $20 Sony Walmart Remote that I can program from other remotes, so I can make it do whatever I want...without spending $200 for a fancy little screen
my uncle has the one you wanna get, the charging station is horrible for it, it takes like ten minutes and just the right touch to get it to charge
buddy of mine has one and i've used it quite a bit at his place. never had any problems using it and the charger is very simple. you uncle might have a faulty one
I considered the 880 when it was on sale for $99, but i didn't really like the button layout. The rechargeable part is nice but i have read a lot of bad reviews for it so i decided to pass.
Then i saw this one for $49 and decided it was what i wanted. The layout seems just about perfect to me.
Learning remotes like that are ok, except you inevitably run out of memory to program more buttons.
I have had this remote for like 5 years
as i replaced shit with new equipment it didn't have the codes and i had to 'learn' more and more functions... eventually it just couldn't hold them all in the memory.
faulkton
faulkton
neverland
natisfynest
BP1Fanatic
BP1Fanatic
