Why is my volume so low with my new DEH80PRS? Should 6..5' or Sub get more power?
I'm using these in my car:
Deh80-prs
Kicker KX650.4
Kicker KX650.4 4-channel car amplifier 120 watts RMS x 4 at Crutchfield.com
Hertz Es250 10" woofer
Hertz Car Speakers and Subwoofers ES250 (Subwoofer 10") from Mad Man Mckay
CDT Es-62i
ES 62i
____________________________________________________________________
-Now I have my subwoofer in bridge mode getting, I believe 325rms?
-Component setup each has their own channel getting 120 rms each right?
First question would be:
Should I have my components setup to get more power by using a bridged mode or should the sub get more power?
I only really want the sub to give a little extra bass not to shake my car obviously.
Second Question:
Why is the volume from my components so low on my system? I know gain is not a volume control & the 80prs has good pre outs.
Is it just because my components are not getting enough power & need to use them in bridged mode?
CDT arent that loud to begin with but sounds like you have your gain or head unit settings set wrong. Are you in network mode or standard mode?
Im in standard mode but ill try connecting another source to see the difference.
What about my wiring should the components or the sub get more power? The sub is cyrrently turned down to be more even with the components.
Don't be afraid to set your volume at 62/62 when you set your gains. It is clean all the way thru. How did you set your gains for the speakers? I don't think you need to bridge your front speakers as 120w at 4 ohm should be plenty for what you have.
I wouldn't be too sure about that. My last 80PRS distorted at 57
408
Some don't have that option. But it does have an internal amplifier otherwise it wouldn't put out the 21x4 it claims to. Check the eq settings...
13
i did end up getting the amp and subs you suggested, looking forward to hearing what it sounds like as soon as the stuff gets here and the weather...
43
They are. But, after using sort of them, i think best way is to root phone and do some real system modifications with Viper.
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
95
s2g-unit
s2g-unit
NY, Redding, CT & Montreal
Jeffdachef
    May 16, 2024
    May 16, 2024
