Why is my voltage drop so awful?
I'm going to cut and restrip my power and ground to the amp, along with replace the fuse in the distro. If that doesn't fix it, I'm putting the other alt in. If that doesn't fix it, I'm selling everything, lol.
Didn't help at all. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
When idling and nothing playing, the front battery was reading different than the rear battery and the amp, which were reading the same. When playing full tilt the amp was dropping to 11.5 (it's hotter today, than before) and the rear battery was dropping to 12.7. There's still a difference between the two, although there shouldn't be.
I think it's time for some pictures of the wiring and connections. There is high resistance or this would not be happening. In a parallel circuit the voltages will be the same unless there is some resistance in series (in a run of wire). I am curious. If you unhook your amp, do the batteries read the same voltage then? If so, then connect the amp again but unhook the remote lead. Now are the batteries the same? If they are still the same, you need to have someone with a DC clamp meter, see what your amp is drawing with no music. If it's drawing greater than an amp or two when not playing anything it needs to be repaired.
Do you mean with the car running or off? Running I assume? Unfortunately, I don't know anyone with a clamp meter, so let's go through the first couple of steps first...
car running, yes. i think you can do what he's saying by pulling the remote and checking. if the same numbers, then re-connect the remote. if that doesnt make a difference, then get the amp checked. testing for a bad amp...
Okay guys:
Testing with car on, HU on, HU volume at 0, remote hooked up:
Front battery: 13.68-13.69
Rear battery: 13.64-13.65
Testing with car on, HU on, HU volume at 0, remote NOT hooked up:
Rear battery: 13.67-13.68
Resistance in the wire connecting the two batteries? I can check my solder joints, since I may have done a bad job on them...
Okay guys:
that resistance might be the length of the wire. it's not much. the resistance you're worried about is between the amp and the rear battery. or maybe internally in the amp. how big is your alt? that should be closer to 14.4v w/ the car running.
It's only an 18' run.
Alt is an aftermarket 136A, but it's a factory replacement, not a true aftermarket designed for car audio. My true OEM alt used to charge at 14.4 during the winter, and as it warmed up it dropped to 13.9. Since then it's dropped further, although it's only gotten cooler out.
hmmmmmmmmmmmmm....... do that same test as up there ^^^ but also measure at the amp. a .01v drop over 18' isn't a worry. i'm curious what the voltage is at the amp with the amp on, volume down VS amp off (remote unhooked). should be very similar and should be the same as the battery shows. might need to find a clamp, or maybe swap a different amp in to try?
Okay guys:
This shows the amp is good, the wire has high resistance somewhere. This happened to one of my dad's hi performance CB installs. He was a die hard solderer until we had this same problem. We replaced it all with crimp ons and it fixed it. That SHOULDN'T happen, but sometimes it does.
Front battery: 13.75
Rear battery: 13.72
Amp: 13.68
Rear battery: 13.74
Amp: 13.74
Honestly, I didn't know the first thing about soldering, I just started doing it on all my lugs one day. I didn't know what a cold solder joint was or what causes it until you mentioned it in this thread. After having learned a thing or two I'm sure that my technique has improved, and I should resolder these terminals.
Can old solder or lugs that have been reused multiple times cause this?
Lord have mercy, I'm gonna have to read this whole thing. I cant believe nobody's got this straight yet.
Soldering is overrated. No is the answer to your question.
hatedonmostly
throwin' hunnits, hunnits
hatedonmostly
Detroit, MI
osl
