KChiefin29
Hi, I just recently set my gains on my JL HD900.5 amp. Using a mulitmeter...I set the speakers at 100 watts @ 4 ohms. The sub channel was set to 500 watts @ 4 ohms.
This equaling around:
20 V on multimeter for speakers
44 V on multimeter for sub
My volume was set at 25, which is roughly 80% of 32...max on kenwood x997. For the sub I used a 50hz frequency and 1000 hz for the speaker test.
With all this said and done....I am very disappointed in the results. I initially was using a JBL GTO-5EZ amp, which in my opinion was much louder and seemed more crisp and clear. I could even hear the tiny details such as finger slide on acoustic pieces... The gains on the JBL was set with their test cd. The switch was made due to the size of the JBL amp...
Now if I had to be honest...The JBL amp got much louder than the JL. I also wanted to mention that I didn't notice any gain in SQ with the JL amp....WTH? I figured I was making an upgrade...but seems like I made a terrible choice going with the JL HD900. Now is this due to the Class AB vs D on the JL amp?
Is it safe to turn up the gains on the JL amp past 100 watts?
I believe the JL @ 4 ohms is rated at 100watts x 4 for speakers and 500 watts x 1 for the sub channel.
If anyone has any advice, please let me know... Thanks.
Setup:
Kenwood X997 HU
JL HD900.5 amp
JL C5 - 650 components
Polk mm651um
Polk SR104 sub
triple layered dynamat extreme on inner and outer door panels + rear.
Setup:
Kenwood X997 HU
JL HD900.5 amp
Polk mm651um
Polk SR104 sub
