Why is my amp going into PROTECT
I always start a installation with a better ground wire, from the engine to the chasis and from the chasis to the battery and from the alt to the + battery. Do that before you install a bigger amp.
If your electrical can't handle 500 watts how do you plan on running 4 times that power?
^^^This. If you actually put that in, you better not turn that thing up, or you'll cook it when your voltage drops to lower than what you are seeing now.
SLIPKANOT
SLIPKANOT
Syracuse, MO
gckless
