amp problem
  1. tjkollmeyer
    amp not sending power to front channels? help!
    Hi, so i recently bought a boss riot r1004 400w 4 channel amp. i also installed a new kenwood headunit, and 4 new kenwood road series 6.5" speakers. all of this was installed nearly from scratch in a van with a gutted interior. i used the factory radio wiring to connect the amp speaker outputs...
  2. C
    Sub randomly stopped working
    My subwoofer has stopped working and will start again every once in a while. The amp powering the sub never shuts off, but the sub stops making noise. I thought this could be the RCA cable, so I tried hooking my phone up to the sub using a 3.5mm to RCA cable, and it worked fine. I figured it had...
  3. J
    Kicker zx750.1
    I've had a kicker zx750.1 laying around for a few years that I had forgotten about since it didn't seem to be functioning properly the last time it was in use. The problem that I had with it was the fact that it seemed as if all of a sudden it was providing dramatically less power than it had...
  4. P
    Amp help
    I have a db drive dual 600w max sub box and an okur 1000.1 amp, I have had this same setup for about 2.5 years. Recently the amp had been going into protection mode I checked all the wires, fuses, connections, and for corrosion, but it kept going to protect. I played the amp by itself for a few...
  5. P
    Amp goes into protection...HELP!!!
    I have an okur 1000.1 amp from db drive and 2 600w db drive subs, I've had this setup for about 2 1/2 yrs and had it in 2 different cars. The only thing I've replaced is the fuse under the hood connected to the battery, that was last year and when I changed cars I got all new wiring. Now about 3...
  6. S
    Why is my amp going into PROTECT
    I got 2 Alpine Type Rs (Dual 4 Ohm). I got em wired down to one ohm. my meter confirms that its one ohm. My 500 watt Memphis Mono is one ohm stable also. When Im listening it will randomly go into protect. i dont believe the wires are shorting anywhere. my only thought is that my voltage is...
  7. J
    Quantum audio qb1000d mono 1000w 2 ohm class ab amp
    Hey guys i need some knowledge i acquired a tri-box with 3 Alpine R-type 12's and a Quantum Audio QB1000D MONO 1000W 2 OHM CLASS AB AMP. I have hooked up the left and right one and it sounds great. I want to hook up the middle one but the question is how should i do that? Bridge it? or just plug...
  8. Why So Cereal?
    Sub keeps bottoming out
    ok so i have a FI Q 18" (fully loaded) off a cadence dakota 1200x1 rms amp. on certain songs and after played for a while, the sub will bottom out on certain songs. (i was told that weird noise was bottoming out) ive searched n searched but all the ones i found were discussing ports...i have a...
