Why does my new sub sound like its "maxing out"
  • 4
Jlaudioeh
canada
I have a new JL audio 13.5" TW5 Shallow driver in an enclosed box. Im powering it with Alpine MRP-M350
Class D Monoblock Amplifier. It sounds fine at low and mid range volume but when i turn it up it sounds like its "maxing out" The sub should be able to handle twice what that amp can put out.....Any ideas?
You might be clipping it into distortion. Maxed out = bottoming out where the voice coils are slamming against the magnet and losing control hearing a lot of mechanical noise. Distortion from clipping just sounds like cr*ap. You either need more power if you expect more out of it. It could also be you are expecting too much out of a shallow sub. Try repositioning the subwoofer, subwoofer placement can actually make you a lot louder depending on where you put it.
Amp apparently tops out at 350W RMS @ 2ohms, sub is 600W. Could be that i am "clipping". I will try playing with the gain but more than likely I am asking too much of the amp
The correct answer is yes, you want both left and right so you get low end information from both channels. It is very common for recording...
38
327
978
10
947
Jlaudioeh
Jlaudioeh
canada
Jeffdachef
    May 16, 2024
    May 16, 2024
