Okay now were are venturing into different territory. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
When building a speaker cabinet, its resonant freq MUST be designed to be outside the operating range of the speaker system. Otherwise when playing this frequency, as you suggest, the enclosure itself will resonate... at best creating non-intended sounds. At worst, yes it will lead to premature deterioration of the enclosure itself.
When building a speaker box, you have 2 choices.. try to raise the res freq of the box above the operating range of the speaker, or you can try to lower it below this range. Most people think you only work to go below it, discussing how heavy their boxes are, how dense and massive etc... not realizing their box's res freq is actually ABOVE their speaker's operating range.
Lowering res freq generally happens by adding mass/weight. The heavier it is, the lower the freq it takes to make it resonate. This is much more common in home audio than car audio. People whoi biuld concrete speaker enclosures are going for a very low res freq, for example. But you dont find many heavy concrete enclosures in car audio.
Raising res freq happens by increasing rigidity. This is generally done by using internal bracing. The box can be infinitely light, so long as it is rigid enough to not flex until it encounters a note above the operating range of the speaker system placed in it. This is, by far and away, the most popular design type in car audio. Even those guys with double wall boxes and triple wall baffles, stiffen it all up with internal bracing. This is what happens when you dont understand what Ive described here... building a box while moving in both directions (adding mass AND increasing rigidity). Although double-walls have other advantages too (added strength through a simple type of lamination). But generally speaking both methods need not be applied.
Quick recap. Adding weight/mass lowers res freq, adding bracing increases rigidity and raises res freq. Either method can acheive the goals you want, so long as you understand this.
Cheers.
