bdawson72
Finally Has Bass Again
Ummmmmmmmmmmmif you smoke the good stuff, the cuts will probably fix themselves.
but it says plus silicon too //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gifIt's probably because that one is latex. Like I mentioned, I get the heavy duty all purpose stuff. It holds almost as tight as wood glue. I can't think of the name brand atm because it's all at my house (I'm in my appt atm).
i do use a fence...and they are mostly straight and fine, but its just a pain in the ***, and i always end up screwing up at least 1 pieceAnd if you don't use a fence when you use the circular saw, you are going to screw up //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
I know. I just saw someone else mention using a fence and then it occurred to me that not everyone else may have came from 3-4 generations of carpenters and taught how to do everything correctly.i do use a fence...and they are mostly straight and fine, but its just a pain in the ***, and i always end up screwing up at least 1 piece
well ****, if walmart didnt have ****ing 20 different kinds of caulking maybe i could pick something worthwhile lol.This would work a lot better than that latex crap. Granted, I'm not sure if there is anything wrong with it, but I wouldn't use it.
http://www.dap.com/product_details.aspx?product_id=25
You line up the straight edge, clamp it down so it cant move, then follow it by holding the saw against it while cutting. At that point its very similar to the method used to cut wood via a fence on a table saw.i tried the fence method but i find it hard to get a straight cut still because either im not cutting in a perfectly straight line, or other times i just have a hard time getting the blade to perfectly sit on my desired cut line, while trying to line up my straight end.
its basically a pain in the ***.
anyone wanna chime in on my DAP purchase?
Any idea where I can purchase one of these moonbeam lasers you speak of?i cut my boxes with a moonbeam laser from goldeneye...they come out perfect every time
