White Noise/Crackling/Whistling After Installing After-Market Head Unit
  • 2
outgoingjake
Hey all. First post here on the forum! Heard very good things about this place, so I figured it was a good idea to start here.
Anyways, I quite recently purchased an after-market head unit (AVH-4200NEX). After getting this installed by Geek Squad, I began to notice what sounded like a hissing/whistling coming from the driver side tweeter (I drive a 2007 Saturn Outlook, so tweeters are separate from door speakers). The auto tech from Geek Squad informed me that the after market radio is amplifying sounds that may have been there with the factory radio and I just didn't hear them until they were amplified. I also soon realized that whenever I hit bumps in my car, the tweeter makes a loud pop/crackle noise. I thought I may have blown the tweeter and that is what caused my issue. SO, I went out and purchased all new Kicker KS Series speakers and had Geek Squad install them. The noises are still there, including the loud pop/crackle when hitting bumps.
There are rare moments that none of these things occur, for a whole driving session (A to B). But usually when I start my car again and move to my next destination, the sounds have all returned. I am not sure if there is anything that can be done to fix this issue, but I certainly hope there is because it is EXTREMELY annoying-- especially considering I am a delivery driver and music is close to a MUST. I would appreciate any and all input!!!
**I had Geek Squad install everything because I work at Best Buy and have the employee discount, otherwise I would have attempted everything on my own!
**EDIT
I just read the sticky thread regarding a proper ground. Could that be my issue?
**EDIT
if youre getting pops and cracks over bumps, it kinda sounds like a loose connection. Are you capable of pulling the deck out? if so, pull it out and ensure all connections are good. If youre handy with a soldering iron, you could cut off all the crimp caps that they likely used and solder and shrink wrap the connections for the best results. I had some cracking in my door speakers a bit ago and i just cut all the connections and recrimped them, shoulda soldered them, but i was feeling lazy and :: insert other worthless excuse for my laziness here :: but it stopped doing it after redoing the connections
I skimmed the manual and did not see any mention of a reset on that model, so bummer if leaving the power disconnected did not help. Maybe Pioneer...
10
4K
The 240 should be 2x40/ 2ch. rated at 11.9v. Should generate close to 50+ @14v rms. Only Rated @4 ohms bridged Mono.. Should be around 125 rms...
You just found your own solution. Move the DSP elsewhere. The RCA is triple protected but not the RCA plugs. I do not know if there is a mesh or...
outgoingjake
outgoingjake
Muskegon, MI
youdoofus
    May 12, 2024
Brendon Jenness
    May 11, 2024
