Whining noise
Emanuel Rodriguez
CarAudio.com Recruit
Hello Guys,
Over the last couple of weeks there has been a small whining noise coming from my door speakers all the time. The whining noise has been getting louder over these past few weeks. Whenever I step on the gas whenever I’m driving the whining noise will get louder. At first I thought it was my power steering but it turns out it was my speakers all along. Any ideas on what it could be?
If it's not the grounds, check the RCA cables are plugged in right. Had one of my cables come out a little behind the deck as there was so little room back there. It was the last thing I checked as it required removing so many panels in that vehicle.
Hello Guys,
It's coming from the radio. The antenna area. Probably a loose cable maybe at the antenna area where you secure the cable and leading to the car radio. Something is loose there. Whining noise. I think it's the antenna.
I still have that same problem. It is intermittent, so It was hard to trace. I checked all my grounds, speaker leads, and even rewired my entire system. Then it dawned on my that it would only happen when my wife was in the car. I found out by asking her to step outside as soon as I heard it. when she did, the annoying sound went away. So, it turns out it was my wife's nagging. I'm afraid there's not fix for that.
You may want to erase this post after a day.
Emanuel Rodriguez
Emanuel Rodriguez
Texas
NorthFramingham
    Jun 30, 2026
