Which wiring harness? (Monte Carlo)
ToNe dEF
22
n/a
Hi, I have an 02 Monte Carlo SS so of course its gonna be a pain to put a system in.
It does have OnStar but I never plan to use it and it does have the factory amp which I’ll bypass when I get aftermarket speakers.
I’ve looked around a bit and found these…
Scosche GM06 (relocate HU)
http://www.cardomain.com/item/SCOGM06B
Scosche DCGM09
http://www.cardomain.com/item/SCODCGM09
Peripheral GMCO
http://www.cardomain.com/item/PERGMCO
Which of those do you think I should go with to keep as much the factory functions as possible. I’m not a fan of the relocation but would do it if it’s the best option.
Also do these keep fuctions like the player staying on after the car is off till a door is opened and things like that?
No retained power from what I remember...the GM-RC01 gives you an accessory line (there's no accessory on the factory harness) and gives you chimes, which you'd normally lose.
Also without the GM-RC01 you'll lose the information center on the gauge cluster
ahh i was close too it lol.
****it... u can use a 2003 harness too if u dont care about door chime, and onstar right?
What about headlights? Right now I dont even mess with them they just turn on as they see fit from the little sensor. Is that some how tied into the HU as well?
Metra GM-RC01 will work, just did an 02 Monte the other day.
Coming back on this I have a different question. Do you remember what the door speaker size was? I thought it was 6 1/2 - 7 because thats what I've seen on other sites but I just seen a site claiming it has 5 1/4. Maybe you could clear this up for me when I begin comp shopping.
ToNe dEF
ToNe dEF
n/a
Randy Savage
