which wiring and which amp
as far as wiring it looks like i am left with an impedance of 1 ohm or 4 ohm is that correct
Yes.
Just look for an amp that does ~400w into either a 1ohm or 4ohm load. You can look for either a mono amp (which will likely do it's power into a 1ohm load) or a 2-channel amp and bridge it (that will do the power into a 4ohm load bridged).
thanks guys, squeak (or anyone else that knows) a quick question to u so getting a two channel that has say 230W @ 2 ohms is the same as 460 bridged @ 4 ohms am i correct... this means that each sub (there is two) is gettin 230 watts correct? thanks
Russxtreme15
Elite Member
Russxtreme15
Lancaster, CA
Russxtreme15
