Which will be louder SVC or DVC
Wicked C5
I am running a 250/1 JL audio amp which gives out the same power no matter what ohm
I was wondering wouldn't I be better to run a SVC sub so all the power would go to one voice coil or stay with the current setup I have now which is a DVC 12 inch Kicker Comp Vr 2ohm that I am running at 1 ohm.
I am only running 1 sub off this amp and will never be changing the configuration
What do you guys think?
Why are you running that kicker at 1 ohm? Its easier for the amp to run at 4 ohms, and jls amps are only rated to 1.5 ohms. To answer your question it doesn't matter just for configuration like Snova said.
-John
The amp seems to be cool with it and it sounds pretty good. It not hot at all and the the low ohm light doesn't come on. I also was wondering since JL audio amp's are only rated at 1.5 ohm if there is a power gain pushing it to 1ohm.
Wicked C5
Wicked C5
Laguna Niguel,CA
Randy Savage
