which subs
bow125106
Just bought a Hifonics BX1605D and was wondering if anyone could suggest a good sub for this amp.........12 or15......The sub will be going in a 01 camaro....I am on a pretty tight budget and new to all this...So i dont know about 1 ohm 2ohm etc etc...........Just some suggestions with budget in mind would be nice...Thanks
Get a 15" l5, CVX, or L7, all these you could get them under 250 at ebay, i have one of those amps with a 4 ohm L7 wired at 2 ohm to get 1100 rms @ 2ohm and it sounds hardcore!!!!
but if you are looking for something cheaper maybe the L5, tough i think 1100rms is a lil too much for the l5.
later, em
get a 4 ohm l7 so you can wire it at 2 ohm load, cuz at 1 ohm is juss too much power for teh l7 or type-r i do believe since its 1600rms and with 1100 rms at 2 ohms it should bang pretty loud.
later, em
depends what you get, but i dont think you will be getting 1600 watts outa that amp. just get a 2 ohm dvc and be careful when to turn it up.
that 15'' type R will slam
well the 12'' is the swr 1222d and the 15'' is swr 1522d. just look them up at ebay, the 12'' is 130 and the 15'' i believe is 215.
if you have the room get the 15'', you need about 6 cubes gross. the 12'' you need no more than 4 cubes gross of room. i have plans for a box for the 12'' type R if you need them.
bow125106
bow125106
arkansas
PSturmer
