Need AMP hElP!!.....
you could do a new amp kit, or you culd use a distro. block.
Amp kit would probably be easier, thats what im doing since i made the same mistake of buying one, and then needing another.
What the heck are you talking about???? Please only post if you know the right answer.
In order to install that, you need to go buy a distrobution block. What that does is you run your main 4g into it then it will split off into 2 or 4 how ever you want depends on the one you buy. You can get one that goes 4g to 8g or 4-4 etc all depends on your amps. I would personaly just get a 4-4 one and then you will run your main wire into it, then attach one amp to each set of power wires that come out that you attach as well. It is very simple. I have a stinger one that has fuses in it that works very nice. There are many you can choose from. Your install would look nice if you bought 2 of these one for your power and one for your ground. But that depends on you and cost. I know in the past I have just ran 2 ground wires off the ground but for a nice install you can get another distro block and do the same as the power.
Here is a link so you can see what they are
http://www.stingerelectronics.com/web/prods/distribution.asp
There are even some that have the ground and power spots on one to make it simple. Just need to find what you want to do and find the right one. This is much easier then trying to add a whole run of wire and hide it. And cheaper sometimes depends on what you buy though
im just doin what i wsa told.. i asked a question about the same topic and was told it would probably be easier to run a second amp kit, so i stopped asking questions.
shanerz21
shanerz21
IOWA
shanerz21
