which subs or this amp?
groesbeck
This is the amp that a have along with the specs and i would like to know which one of the speakers listed below would you use in a bandpass box to go into a 99 surburban?
Hifonics BX2005D
Class D Monoblock Amplifier
View larger and other pictures
Hifonics BX2005D
Product ID: bx2005d | Product SKU: 3491
Click here to shop for other Hifonics car audio products.
Product Description:
1-Channel / MonoBlock for Subwoofer Operation
RMS Power Rating: 1300 watts x 1 chan. @ 2 Ohms
RMS Power Rating: 2000 watts x 1 chan. @ 1 Ohm
Super D-Class AMplifier Topography
Ultri-Fi MOSFET Outputs
Complementary High Speed MOSFET Power Devices
MOSFET EXVP ( Exponential Vari-Power Supply)
SPC Twin Turbo Torroids with Simpatico Coil Design
21st Anniversary Edition Heatsink Design
Illuminated Hifonics Logo
Power and Protection LEDs
Gold RCA Inputs
Adjustable Input Level: 0.2V - 9V
Accu-Cross Crossover: LPF (35 - 250 Hz), Subsonic (15 - 35 Hz )
Balanced Line Inputs with optional Hifonics XX-BLD
RCA Outputs: 1 Pair
Gold 2-Gauge Power Connectors
Low Pass Filter: 35 - 250 Hz
Bass Boost: 0 - 18 dB @ 45 Hz
Phase Shift: 0 - 180 degrees
24 dB Subsonic Filter ( 15 - 35 Hz )
Dimensions: 16.5" L x 10.39" W x 2.63" H
1-year Sonic Electronix warranty
Amplifier Specifications:
Number of Channels 1 - Mono
RMS Power (4 ohms) 650 watts x 1 chan.
RMS Power (2 ohms) 1300 watts x 1 chan.
RMS Power (1 ohm) 2000 watts x 1 chan.
Bridged RMS Power Not Bridgeable
Peak Power Output 4000 watts approx.
Min. Impedance Unbridged 1 Ohm
Min. Impedance Bridged Not Bridgeable
THD @ Rated RMS Power 0.08%
Speaker Level Inputs No
Amp Preamp Outputs Yes - 1 Pair
Built-in Crossover Yes - LP
High-Pass Crossover N/A
Low-Pass Crossover 35 Hz - 250 Hz
Subsonic Filter 15 Hz - 35 Hz
Signal-to-Noise Ratio 95 dB
Channel Separation N/A
Bass Boost 0 - 18 dB @ 45 Hz
Bass/Gain Remote N/A
Fan Cooled N/A
Fuse Rating N/A
Warranty 1-year SE
HK15X2
2000W RMS
4000W MAX
Sensitivity: 90.6dB @ 1w/1m
Mounting Depth 9 3/8”
Mounting Diameter 14.2”
Vented Box: 5 cu/ft
Port: 80 sq/in 13.0” Long
Sealed Box: 2-2.5 cu/ft
SPL SPLW15 - 15" 2800 Watt Competition Ready Car Audio Subwoofer
2800 watts power handling
1400 watts RMS
Sold Individually
340 oz. magnet
4" BASV/Kapton hybrid 18 awg voice coil
FS 29.1(Hz)
Vas 1.6 cu.ft.
Qes: 0.52 . Qms: 4.06 . Qts: 0.31
Xmax: 0.59"
SPL 92 dB
Ported box: 3.4 cu. ft.
Tuning: 40 Hz
Port size: 4" (dia) x 10" (length)
# of ports: 2
Cloth laminated paper cone with MD6 coating
Dual 1 ohm voice coil
Die cast aluminum basket
Aluminum/chrome dust cap for extra rigidity under extreme conditions
Black wrinkle finish with Diamond cut
Chrome finish front & back plate
Large roll treated foam surround
One piece, 360º rubber gasket
Dual conex spider
Woven tinsel lead through spider
Chrome binding post terminals
groesbeck
groesbeck
norfolk,va
groesbeck
