Which one should I keep for my rears????
Doola36
Okay I have a pair of Infinity Kappa 60.9cs and a pair of CDT EF61NEOX coaxial 6.5s. My question is which one should I keep and put in the rear of my Titan? I purchased the comps for my car but I have changed my mind going that route. Here are the specs.....
CDT Audio EF-61NEOX - CDT Audio 6.5" Neodymium Slim Coaxial Speakers
These Slim Neodymium Magnet designed Systems are The Installers Choice when and shallow door and Slim Designed Audiophile Speakers are required to fit but yet deliver a clean natural high quality sound performance from top to bottom.
Stamped Steel Frame
Fabric Fiber Glass Cone
Buytal surround
1" VC 26mm
Mounting depth: 2.187" (55.55 mm)
Mounting hole: Cutout diameter 5.625"(143 mm)
Frame OD:Outer diameter 6.5" (165.1 mm)
Designed for perfect performance in (infinite) well dampened stock Door and deck Locations
3/4" Angled Silk Dome Tweeters
Power handling: 100 Watt RMS @ 120Hz High-Pass
Frequency response: 65-20kHz
Sensitivity: 90.8 dB
Impedance 4Ohm
CDT Audio EF61NEOX CDT Audio EF 61NEOX 6.5" Neodymium Slim Coaxial
Infinity 60.9cs - Infinity 6.5" Kappa Component Speaker System
• 6-1/2" component speaker system includes woofers, tweeters, and crossovers
• 2-ohm impedance for extra power (compatible with all factory or aftermarket car stereos)
• Plus Oneᆴ woven-glass-fiber woofer cone with hi-roll rubber surround
• 1" ultra-high frequency textile dome tweeter with I-Mount" and Starfish" for multiple mounting options
• 2-way external crossover network with tweeter level adjustment
• direct-connect crossover dongle
• power range: 2-90 watts RMS (270 watts peak power)
• frequency response: 45-35,000 Hz
• sensitivity: 93 dB
• woofer top-mount depth: 2-7/16"
Doola36
Doola36
SoCal
Doola36
