JayWheezy 10+ year member
I've got big plans for my 2004 Nissan Xterra. In the future, I will be looking for some midbass to add to my front stage. As of right now, I have HAT Unity 5.25"s for the midrange, along with the Unity tweets which will be on axis along my A Pillars. I am currently having a custom tline box built for my IDMax10 V.4 by CSCSTang. I am going to be running the IDMax off of my Soundstream ref1.1000. Originally bought a PPI I350.2 to run the HAT's, however since then, I've bought a Pioneer 80PRS, and will attemp to run active for the first time. That being the case, I will eventually be looking to swap amps as well. Already have most of my wire, all skyhigh ofc. I've been following up a lot of KHA's builds, trying to learn as much as possible. I have about 20sq ft of Vibraflex(Gator Skin), and will be adding quite a bit of Raamat bxt II and Ensolite PS, budget mlv, decoupler, from Home Depot and for absorption, either some denim insulation or compressed fiberglass from ceiling tiles, if I can find it locally ; 4 ft. x 8 ft. Acoustical Barrier-DB348X96BX - The Home Depot ; UltraTouch 48 in. x 6 ft. Radiant Barrier-30000-11406 - The Home Depot ; UltraTouch 16 in. x 48 in. Denim Insulation Multi-Purpose Roll (6-Pack)-60306-16482 - The Home Depot
Hoping to really make this vehicle sing. Now that you all have a little background info, my question to you all, is what are some sets for midbass you recommend adding to the front stage that would blend well? I would be looking to spend around $300 on them, however I am not dead set on that. Not looking to buy right now, mainly ideas for the near future. Leaning more towards 6.5"s as I am thinking of placing the midbass in the stock speaker locations of the doors, and fabricating something for the HAT midranges either to the side of the stock locations, or preferably if I can, above. Any tips/suggestions are welcome!
