I have 2 12" Volfenhag subwoofers! Also I have some Kenwood 12" Subs! I need to know which is technically best, because I want the best system I can make with what I have. I've seen the kenwoods bump big time for others, but they never did that much for me. I felt like I was going to blow them when the Volf's could take the same heat without flaw. Maybe it was the way I was wiring idk im a noob with systems. I would like to know which is best here are the specs for both!
Kenwood 12" Specs:
12" Single 4 ohm KFC Series Car Subwoofer
Power Handling:
Peak: 1200 watts
RMS: 400 watts
Polypropylene cone woofer
Urethane foam surround
Linear spider design for increased excursion
Spring post terminals
Double stacked magnet
Frequency response: 39-300 Hz
Sensitivity: 86 dB
Volfenhag 12" Specs:
12" Dual 4 ohms Competition Subwoofer
Power Handling:
Peak: 1000 watts
RMS: 500 watts
Impedance: Dual 4 ohms
Reinforced aluminum curvilinear woofer
Oversized butyl rubber surround
5 spoke Die-cast aluminum basket
2 Flat ultra excursion
Double damper magnetic motor assembly
4 Layer Dual 4 Ohm high temperature black aluminum voice coil
160 oz. Double stacked ferrite magnet structure
Sensitivity: 90 dB
Kenwood 12" Specs:
Power Handling:
Peak: 1200 watts
RMS: 400 watts
Sensitivity: 86 dB
Power Handling:
Peak: 1000 watts
RMS: 500 watts
Sensitivity: 90 dB
