which fuse to use??
K3VIN
So my fuse been popping like crazy so i decide to just change the whole thing just to make it easier to change later. I been using the ANL fuse holder for awhile but now i wanna change to the AGU. The fuse i got in there are 150A but the AGU uses different style of fuse.. so what fuse should i be using when switch to the AGU??
amp 1 MRD-M1005
amp 2
profile CA640
SUB type X
it didnt happen before but i just reinstall my system and i pop 3 fuses already..
then you are most likely shorting out somewhere. REDO/REcheck all your power connections immediately.
Plus I don't THINK AGU's go to 150A.. the highest I've heard of I thought was 100A. There might be some marine AGU's that go to 120A, but I'm not sure.
nah i am not thinking of switching it to fix the problem i just wanna know what fuse should i use if i change the whole housing.... as of what happen when it pop i got nooooooooo fuc ideaaaa
Check ALL of your wire connections. This includes all power and ground cables and wires and speaker wires pos and neg. If you're running seperates in the front, where is the x-over located? If it's in the doors, is it proctected from water? If not, relocate it, or wrap it with a plastic bag and zip tie the end together. There is a short in your electronical system and from what I read (doing my own reasearch) this is one of the problems overlooked.
Again check ALL cables and wires, it may be the culperit.
Hope this helps.
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
K3VIN
K3VIN
Orange County , CA
da12b
