espguitarist91
yep
Well im about ready to put in my new amp/subs. The amp is a hifonics 1606d ran @ 1ohm. Rated at 1600 watts, but im going to take it easy on the gains as i only need 1400 or so. I had an infinity 1240 ran off of 300 watts with the gain set properly. At idel, there was a lot of dimming. I have a 91 deville with a 140a stock alternator. That shouldnt be happening, should it? Well im guessing theyre is a bad ground or connection somewhere, hopefully. Im going to do the big 3, but i can only afford 4 gauge. Im guessing it should be fine because the lenght is so short, not much voltage drops can haapen. Does it sound like a bad connection? ANd will 4 gauge be fine for the big 3?
Thanks
Thanks
