help wiring up Alpine processor!!!!
Spud2388
"The Spud-n-ator"
I just got an Alpine pxa-h510 processor, and need a little comfirmation on hooking it up. Thereis a yellow wire, black wire, and two blue w/ white wires coming out of the process. Where do these go?
Does it go:
yellow- constant 12v source
black- ground
blue w/ white- wired to remoted turn on on HU
blue w/ white- amps?
whats getting me is the remote turn on's. There's two of them, and I don't know which one goes to the HU and which on goes to the amps, if they even go to the amps. I'll post pics if yall need them.
if you are going to connect the pxa-510 to an alpine h/u via the ai-net cables then you only need the yellow and black wires to be able to power the proc, and for the remote turn on for the amps you could use the one from the h/u since the one on the procc is not clear which one is it, the reason that they have two blue/white wires is one for the remote turn on for the amps and the other one is to turn the procc on when used with non ai-net h/u, hope this helps.
Spud2388
"The Spud-n-ator"
Spud2388
Iron Station, NC
sl600
