which battery under the hood?
select127
ok fellas my stock batt. is working fine, never died on me but sometimes it would crank up a lil slower than normal. i wanna get either a red/yellow top but which model do yall recommend? i tried searching on the website but it didnt show for my car(01 I30). Im also running a stinger batt. in the trunk if that helps. oh and i noticed that my sub isnt hitting as hard as when i was running 4ga wire from stock batt to second batt, now that im running 1/0ga from batt to batt and grounded second batt. with 1/0ga as well, what do yall think the problem is? might it be that ground wire from first batt is still the stock one? or ground on second batt might need to relocate?
yellow top dual purpose...there is a reason why optima doesnt warranty red tops for audio use. hear alot of people say "under hood isnt getting deep cycled..blah blah blah point is its part of the same circuit reguardless . key on key off same battery is in use! doesnt take a voltage drop to 12.5v for it to be "used by the system" either........
select127
select127
Florida
audiolife
vegang
vegang
