Which amp should I use for kicker 12inch comp?
do some simple math with me...
137.5 x 2 =?? ...275...
275x2=??....550 and thats what the amp does rms is 550...depending on ohm load
all crunch model #'s are the max rating so 1/2 the max is the rms 550+550 = 1100 //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
well I just typed in the model number and I got this.
Kicker Comp Series C124 12" 150W RMS 4 Ohm Car Subwoofer
12" Comp Series Subwoofer
Peak Power Handling: 300W
RMS Power Handling: 150W
4 Ohm Impedance - Single Voice Coil
Vacuum Formed Polymineral Cone With ISD (Inverted Structural Dome)
Rear Cone Brace
Double Stitched Surround
Optimized Polyfoam Ribbed Surround Radius
High-Temp Polyimide Film Voice Coil Former
Ultra-Length Voice Coil
Sleeved High-Power Tinsel Lead Wire
Spring-Loaded Nickel Plated Terminals
Two-Piece Vented Hyper-Extended Blackened Pole Piece And Backplate
Perimeter Venting In The Basket And Motor Assembly
Sealed Box Volume 1.25 - 3.5 Cubic Feet
Ported Box Volume 1.75 - 2.25 Cubic Feet
Frequency Response 27 - 500 Hz
Mount Depth 5-3/4"
Cutout Diameter 11-1/8"
so that means my sub will take 4ohms from my sub not 2 ? sorry im a n00b at at this car audio.
Right now im running
CDX-GT250MP
KICKER 11DS693
140 Watt 6X9" Coaxial Speakers
Crunch P751 Amplifier
and from the crunch amp im using right now i feel like im not using all the power...cuz its 700 watt amp but its came in the crunch box package so yeah. when i turn it up loud not to loud but a good amount my sub sounds all distorted but i know this kicker aint like that so im tryin to find a good amp for it so it sounds nice and clean..
if your only pushing one kicker comp 12, you need a amp that does 150rms @ 4 ohms. if you go much higher your risking blowing that sub.
and we really cannot tell you WHICH amp to get. the market is huge, many choices. pick out an amp, and run it by the forum and see what response you get. personally, with how cheap a comp is, you should go whead and get to, by a 300 watt rms amp @ 2 ohms. and no regardless of the stories that rms doubles from 4-2 ohms, most of the time it doesnt.
dont pay attention to max wattage, their "usually" lies. match the rms of the sub to an amp.
normally i would say dont buy a crap audio boss or pyle etc. but in this cirumstance pushing a low wattage, it really wont make a differnce.
Crunch CRBX12 Bass Packages - Car Subwoofers at Onlinecarstereo.com
thats where your amp came from... part of a diy kit
it is only 375rms at 2 ohms...your sub is 4 ohms... you are getting around 185 rms and thats it... thats why it sounds like crap...your overdriving that tiny amp trying to get volume that it cannot produce..
either that or your settings are all wacked out
problem is both amp choices you gave give you 500 rms you only need 250 rms... too much more and you will roast that sub...
PZT500.2
500 Watts 2-Channel Class A/B Car Amplifier
4 ohm 65 watts x 2 chan.
2 ohm 125 watts x 2 chan.
Bridged, 4 ohm 250 watts x 1 chan.
Total max power output: 500 watts
MOSFET PWM power supply
DC, speaker short, thermal, and overload LED power indicators
Tuned Bass EQ (0-12 dB bass boost at 45 Hz)
Slow un-mute turn-on enables a safe soft start
2/1 Channel operation for speakers or subwoofers
Full range RCA line output connections
Adjustable voltage level (0.2-6V)
1 Pair of preamp RCA outputs
Stereo and mono switch
Crossover switch for low-pass filter, high-pass filter, and full
Illuminated Crunch embossed logo on the face of the amplifier
Power and protection LED diagnostic indicator
Adjustments and controls conveniently located on the front of the amplifier
Aluminum alloy heatsink for efficient heat dissipation
Nickel-plated RCA level inputs
Nickel-plated screw terminals
Variable high-pass filter (60-1,200 Hz)
Variable low-pass filter (30-250 Hz)
Frequency response: 10-45,000 Hz
Dimensions: 9-1/2"L x 10"W x 2-3/16"H
that crunch sounds like a good choice. run it off ONE channel for the time being. dont pay attention to it supposed 1000 watts max. thats BS. the good thing about your choice of amp is, once you decide to break down and buy another kicker comp. 12, you can just add it on the other channel and it will work fine. so you have room for upgrade later. comps are cheap, but a really good starter sub. dont count on that amp putting out much more than 700 watts total AT BESt.
xroshx
xroshx
Escondido, California, United States
xroshx
