Which amp should I get??? Need help!!
New amplifier? I recommend SoundStream Rubicon 1.1600D-$198.00 free shipping at billselectronics on e-bay w 1yr warranty, add $29.99 for 3yr warranty, orRefurbed same amp that comes w 3yr warranty for $174.90 free shipping at carstereoneeds on e-bay.My recommendation for good solid new school stle mono blocks.Old school? You may be able to find something cheaper, and more BRUTE, with a smaller foot print as well, Like the Hifonics VII/VIII series amps, Autotek Mean Machines /Zed Audio made amps.//content.invisioncic.com/y282845/emoticons/imo.gif.3a57bcc70a4835dc53e86ffae1a0b041.gif
//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Sundown SAZ1200 or 1500, American Bass 120.1 or similar (probably more brands use same/similar board)would do .75 ohm. JL 1000/1 if you can pick one up used in the low 300$ range is a good match. I like old school amps, but they're generally huge current hogs so you need a rather beefy electrical to get one to make 1000W. Not much will give you that sort of power @ 3 ohm so IMO you should look for a better quality brand "1 ohm stable" amp... most of the good ones will drive .75, a lot of the mainstream or bargain brands will be more likely to go into protect or up in smoke.
powerbass xta 1500 is .75 stable the rubicon is not. and it is not the old school version, they are ok at best i know these amps well as i sell alot of them locally
Pioneer lists the wattage different than sonic. Pioneer says That amp listed will do great with these speakers. You can play em at 125w no...
Have you check to see if the prefab would fit...
13
For the sub you want to run.. The 700.1 will be more than enough power and enough Head room for that sub. For the Price? And the sub you are...
13
Your skar amp will catch on fire if you go full power?
I'll suggest a JP8 amplifier. I believe you can wire your sub to 2 ohm. It's Dual voice coil 4 ohm, correct? JP8 @ 2 ohm does 900 watts.
MrKapone
MrKapone
Austin,Texas
audiobaun
Decebal
    Jun 10, 2024
