Which amp poll.
Most efficent amp at .5 nominal
  • Total voters
    17
Amp models would help also lol. I love sundown if you can afford (the sae line isn't that expensive but the other line is). Orion xtr amps are cheap and put out real good numbers though.
I think Vital power and b2 use same / similar guts on comparable amps. Sundown scv-7500d can be had for around $2000.
VP 700.1 can be had around $1100, and probably the b2 also I am assuming. Orion HCCA8000.1D can be had for just shy of $1100.
It comes down to what you want. You have a budget or can you get a good deal on 1 out of the bunch?
I think Vital power and b2 use same / similar guts on comparable amps. Sundown scv-7500d can be had for around $2000.VP 700.1 can be had around $1100, and probably the b2 also I am assuming. Orion HCCA8000.1D can be had for just shy of $1100.
The money doesn't matter really. I just want the most efficent amp.
8k plus models
Orion hcca 8000.1d or 110001d
Vital power is supported to be I guess 7kw but it does more.
The b2 M1U
SUNDOWN 7500
I might end up doing 18v so I'm not sure. Only one that is 18v stable is the VP
Papermaker85
Banned
Papermaker85
New orleans LA
Papermaker85
vegang
vegang
