Where should I add bracing?
Let's compare a little
In this picture, the braces are at least twice as wide as the thickness of the wood. Correct ?
What happened in the translation to this ?
I understand the bracing in the plans that moe provided you. The bracing configuration will work if constructed properly my man. You could brace it with 10" thick titanium bars if you want. But what good is the strongest bracing in the world if the enclosure it's in isn't up to par. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
you can get them at any building store.
Same place where you get your mdf
like btnhfan said nothing stronger.
Also you dont have to worry about about the displacement of them cause they take up so little it dont affect anything.
just make sure you use silicone to seal each end where it goes through the box.
Only bad thing is that u can see them and some people dont like it.
i said that mainly to see what would be on each end of the rod I know what a steel rod looks like //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Raisedin305
Banned
Raisedin305
Miami,FL
Raisedin305
