When my trunk is open you can really feel the bass compared when it’sclosed
100% but I think it depends on the overall application and not just being in phase. Almost all the big 4th,5th,6th order builds have subs firing at each other
The distance from the subs to the hatch to the subs is directly cancelling in the bandwidth. The reflected wave is cancelling the original wave. Hence when he opens it the cancellation goes away. Move the subs 4-8 inches from the hatch and it will sound better.
This was my thought as well, though this will perform like a 4th order so results will be unpredictable. The issue I see is how far forward from the rear hatch the subs are. That's usually a recipe for cancellation and some nulls.
The subs ae pretty far forward that's true but anything will be an improvement to having them in a beauty-queen, halfazz 4th/sealed setup in the center of the vehicle like he has now.
I cringe just looking at it.
I'll illustrate what I said above. The 1st pic is basically what you have now without the hard floor as drawn.
I bet as long as the subs are in phase changing it to this will make a marked improvement as long as there's some space to the tailgate.
I'd make sure it has a solid floor and back wall along with changing it to what's shown (or close) if it was me.
Give it a try... its only wood.
Even though op hasn't been on/replied I really hope he tries out @shredder2 advice. definitely interested to see what the outcome would be. And if he does def needs to make a video.
I too generally use the factory carpet to make my templates. It's also a good idea to put layer of butyl damping material under the MDF too...
754
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
It will probably change your tuning. I've seen bigger numbers off of much less power from walling at the rear seats, but Terry "trunk king" Brock...
Thanks all for your responses! In regards to the dB meter suggestions, I ended up using my Blue Yeti microphone which supposedly can handle up to...
Tiltz
Tiltz
New York
MattinMO
SPLBassJunkie
    May 21, 2024
    May 20, 2024
